Enables BOOTP Relay v6. This can be done across the VR or on a per VLAN basis.
| bootprelay | BOOTP Relay service. |
| ipv4 | DHCPv4 BOOTP Relay service. |
| ipv6 | DHCPv6 BOOTP Relay service. |
| vlan_name | Specifies a VLAN name |
| vr | Uses a specific virtual router name. |
| vr_name | Specifies a virtual router name. |
| all | Enables all VLANs. |
IPv4.
Use this command to enable BOOTP Relay across the VR or on a per VLAN basis.
The following example displays IPv6 bootprelay information:
* switch # show bootprelay ipv6
BOOTP Relay: DHCPv6 BOOTP Relay enabled on virtual router "VR-Default"
BOOTP Relay Servers : 2001:0db8:85a3:0000:0000:8a2e:0370:7334
2001:0db8:85a3:0000:0000:8a2e:0370:7335
2001:0db8:85a3:0000:0000:8a2e:0370:7336
2001:0db8:85a3:0000:0000:8a2e:0370:7337
VLAN "Default":
BOOTP Relay : Disabled
VLAN "v1":
BOOTP Relay : Enabled
BOOTP Relay Servers : 2001:0db8:85a3:0000:0000:8a2e:0370:7338
Interface ID : v1-12
Remote ID :v1_remId
Prefix Snooping : Disabled
VLAN"v2":
BOOTP Relay Servers : 2001:0db8:85a3:0000:0000:8a2e:0370:7339
Interface ID : 100 (Default)
Remote ID : 00:04:96:52:A7:1B (Default)
This command was first available in ExtremeXOS 15.5.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
